Create the solution
When creating a new FluxMotor solution, users can name it and choose the part type.
Note: The Outer Slot part can be
imported to FluxMotor for all types of machines with inner rotor (in other
words, outer stator), including:
- 3-Phase / n-Phase synchronous machine with permanent magnets – Inner rotor
- 3-Phase reluctance synchronous machine – Inner rotor
- 3-Phase wound field synchronous machine – Inner salient pole – Inner rotor
- 3-Phase induction machine with squirrel cage – Inner rotor
