Edit solution
From the Solution Browser, double-clicking the FluxMotor solution allows users to view and select the bodies included in the solution.
  • Bodies created via Catalog functions (e.g., Inner Magnet) are automatically assigned to the FluxMotor solution.
  • For bodies generated through the Sketch Environment or Import CAD, users must manually add them to the solution after creation.
