/LINE/SEG
Block Format Keyword Definition of the line segments.
| /LINE/SEG/line_ID/unit_ID | |||||||||
| line_title | |||||||||
| seg_ID1 | node_ID1 | node_ID2 | |||||||
| seg_ID2 | node_ID1 | node_ID2 | |||||||
| etc | etc | etc | |||||||
| seg_IDn | node_ID1 | node_ID2 | |||||||
Definition
| line_ID | Line group
| unit_ID | Unit identifier (Integer, maximum 10 digits) |
| line_title | Line group
| seg_ID1, seg_ID2, seg_IDn, | List of segment
identifiers (optional) (Integer) |
| node_ID1 | Node identifier 1 for
segment (Integer) |
| node_ID2 | Node identifier 2 for
segment (Integer) |
- Lines are used to define interfaces in 2D analysis and interface TYPE8, TYPE11 and TYPE20 in 3D analysis.
- All nodes must belong to a shell, brick, triangular shell, truss, or beam element.
