/LINE/EDGE
Block Format Keyword Selected edges from given surfaces as lines.
/LINE/EDGE/line_ID/unit_ID | |||||||||
line_title | |||||||||
surf_ID1 | surf_ID2 | surf_ID3 | surf_ID4 | surf_ID5 | surf_ID6 | surf_ID7 | surf_ID8 | surf_ID9 | surf_ID10 |
Definition
line_ID | Line group
unit_ID | Unit Identifier (Integer, maximum 10 digits) |
line_title | Line group
surf_ID1, surf_ID2, ... surf_IDn | List of surface
identifiers (Integer) |
- Lines are used to define interfaces in 2D analysis and interface TYPE8, TYPE11 and TYPE20 in 3D analysis.
- All nodes must belong to a shell, brick, triangular shell, truss, or beam element.
