Jump to main content
Radioss
Radioss
2026
Index
  1. Home
  2. Radioss Reference Guide
  3. Starter Input
  4. Groups(Sets)
  5. Boxes
  • Welcome
  • What's New
    View new features for Radioss 2026.
  • Radioss Overview
    Radioss is a leading explicit finite element solver for crash and impact simulation.
  • Tutorials
  • Radioss User Guide
  • Radioss Reference Guide
    • File Extensions and Formats
      Current Radioss format uses the 12x extension format.
    • Single File Input
    • New Keywords in 2026
    • Starter Input
      • 2D and 3D Analysis Options
      • Starter Keywords Syntax
      • Smooth Particle Hydrodynamics (SPH)
        The Smooth Particle Hydrodynamics method formulation is used to solve the equations of mechanics, when particles are free from a meshing grid.
      • Computational Fluid Dynamics (CFD)
      • General Controls
        Block Format Keyword In this group, keywords are used to set default value, global parameter, analysis type, input/output print, damping and ALE and CFD treatment for the whole model. For default value, it is still possible to overwrite in each specific keywords.
      • Nodes
        Block Format Keyword In Radioss, two node types are available. They use Cartesian coordinate to describe the position of each node.
      • Elements
      • Component and Parts Organization
        Block Format Keyword In this group, keywords are used to combine material and property information (/PART), assemble model (/SUBSET) or define a separate model (//SUBMODEL).
      • Interfaces
        Block Format Keyword Interfaces solve the contact and impact conditions between two parts of a model. Several interface types are available in Radioss and use different contact treatments.
      • Materials
      • Properties
      • Monitored Volumes (Airbags)
        Block Format Keyword Monitored volumes can be used to model an airbag, tire, tank, or any closed volume.
      • Constraints
        Block Format Keyword Radioss supports several different kinematic constraints, which are mainly used to impose acceleration, velocity, displacement or temperature in structure or constraint the moving of structure. They are mutually exclusive for each degree-of-freedom (DOF). Two kinematic conditions applied to the same node may be incompatible.
      • Load Cases
        Block Format Keyword In Radioss the following load cases are available. Stress/strain as initial state could be considered by modeling, as well as pressure, gravity, and thermal load.
      • Tools
        Block Format Keyword In this group, tools like transformation, frames, skews, and curve are introduced.
      • Groups(Sets)
        • /GRBEAM
          Block Format Keyword Beam Groups
        • /GRBRIC
          Block Format Keyword Brick Groups
        • /GRNOD
          Block Format Keyword Node Groups
        • /GRPART
          Block Format Keyword Describes the part groups.
        • /GRQUAD
          Block Format Keyword Describes the quad groups.
        • /GRSH3N
          Block Format Keyword Describes the 3 node shell groups.
        • /GRSHEL
          Block Format Keyword Describes the shell groups.
        • /GRSPRI
          Block Format Keyword Describes the spring groups.
        • /GRTRIA
          Block Format Keyword Describes a group of 3 node solid elements.
        • /GRTRUS
          Block Format Keyword Describes the truss groups.
        • /SET
          Block Format Keyword Defines a general entity set which can be referenced by other entities.
        • Boxes
          • /BOX/BOX
            Block Format Keyword Describes the box as a result of the combination of a predefined list of boxes.
          • /BOX/CYLIN
            Block Format Keyword Describes a cylinder box for entities selection.
          • /BOX/RECTA
            Block Format Keyword Describes a rectangle box for entities selection.
          • /BOX/SPHER
            Block Format Keyword Describes a spherical box for entities selection.
        • Lines
        • Surfaces
      • Adaptive Meshings
        Block Format Keyword Adaptive Meshing is used in metal forming to divide the element to better describe the geometry. /ADMESH/GLOBAL and /ADMESH/SET are not available for SPMD computation.
      • Output Database
        Block Format Keyword Time histories output for different element groups, section output, or gauge output are described in this group.
    • Engine Input
    • LS-DYNA Input
      This manual provides a list of LS-DYNA input files available in Radioss.
    • Multi-Domain
      This manual contains the description of the keywords for the Radioss Multi-Domain.
    • Obsolete Keywords
      Keywords that are still supported, but no longer maintained (*) are considered obsolete.
    • Other Files
    • Definition
  • Radioss Example Guide
  • Radioss Verification Problems
  • Radioss Frequently Asked Questions
  • Radioss Theory Manual
  • Radioss User Subroutines
Boxes
Input Type Keywords: Box
Keyword
Input Type
/BOX/BOX
Complex box definition
/BOX/RECTA
Box type - Rectangle
/BOX/CYLIN
Box type - Cylinder
/BOX/SPHER
Box type - Sphere
  1. A box is used for:
    • a simple group definition (/GRBEAM, /GRBRIC, /GRNOD, /GRQUAD, /GRSH3N, /GRSHEL, /GRSPRI, /GRTRUS, Lines, Surfaces) - all entities within the box are included
    • a complex box definition (see /BOX/BOX)
  • /BOX/BOX
  • /BOX/CYLIN
  • /BOX/RECTA
  • /BOX/SPHER
On this page
  • Input Type Keywords: Box
  • Comments
© 2025 Altair Engineering, Inc. All Rights Reserved.
