/BOX/SPHER
Block Format Keyword Describes a spherical box for entities selection.
| /BOX/SPHER/box_ID/unit_ID | |||||||||
| box_title | |||||||||
| N1 | Diameter | ||||||||
| Xp1 | Yp1 | Zp1 | |||||||
Definition
| box_ID | Box identifier. (Integer, maximum 10 digits) |
| unit_ID | Unit identifier. (Integer, maximum 10 digits) |
| box_title | Box title. (Character, maximum 100 characters) |
| N1 | Node identifier. (Integer, maximum 10 digits) |
| Diameter | Diameter of sphere. (Real) |
| Xp1 | X coordinate of point
P1. (Real) |
| Yp1 | Y coordinate of point
P1. (Real) |
| Zp1 | Z coordinate of point
P1. (Real) |
The node N1, or the point P1, is used to define the center of the sphere.Figure 1.
- A box (SPHER) defined above is used for:
