/LINE/SURF
Block Format Keyword Definition of the lines which belong to given surfaces.
Enter selected items numbers (any number may be input, 10 per Line).
/LINE/SURF/line_ID/unit_ID | |||||||||
line_title | |||||||||
item_ID1 | item_ID2 | item_ID3 | item_ID4 | item_ID5 | item_ID6 | item_ID7 | item_ID8 | item_ID9 | item_ID10 |
Definition
line_ID | Line group
unit_ID | Unit identifier (Integer, maximum 10 digits) |
line_title | Line group
item_ID1,item_ID2, ... item_IDn | List of surface
identifiers (Integer) |
- Lines are used to define interfaces in 2D analysis and interface TYPE8, TYPE11 and TYPE20 in 3D analysis.
- All nodes must belong to a shell, brick, triangular shell, truss, or beam element.
