| Unused materials |
Checks for materials that are not referenced by a
component. |
Lists all unused materials. |
Deletes unused materials. |
Not supported. |
| Unused properties |
Check for properties that are not used in the model. |
Lists all unused properties. |
Deletes unused properties. |
Not supported. |
| Property is missing a card image |
Checks for properties that do not have a card image. |
List all properties that do not have card images. |
Not supported. |
Opens the Property Create tool. |
| Property missing mass value |
Checks if mass properties that do not have element mass
defined. |
Lists all Mass properties that do not have mass assigned. |
Not supported. |
Opens the Property tool. |
| Damper property is missing Damping and Mass value |
Checks if Damper properties are missing the Damping or Mass
value. |
Lists all Damper properties that do not have damping/mass
assigned. |
Not supported. |
| Beam Property missing HyperBeam Section |
Checks if Beam properties are missing HyperBeam sections. |
Lists all Beam properties that do not have beam section
properties assigned. |
Not supported. |
| Empty Components |
Checks if components have one or more elements. |
Lists all components that do not have elements. |
Deletes empty components. |
Not supported. |
| Unsed Sets |
Check if sets are not used in the model. |
Lists all unused sets. |
Deletes empty sets. |
Not supported. |
| Empty sets |
Check if sets are empty. |
List empty sets. |
Not supported. |
| Empty groups |
Checks if groups have either a master entity or slave entity that
are assigned a contact surface/set. |
Lists all groups with missing master and slave entities. |
Deletes empty groups. |
Not supported. |
| Empty contactsurfs |
Checks if contactsurfs are assigned any elements. |
Lists all empty contactsurfs. |
Deletes empty contactsurfs. |
Not supported. |
| Unused Sections |
Check if there are any unused Beamsections defined in the
model. |
List all unused Beamsection collectors in the model. |
Deletes unused beamsections. |
Not supported. |
| Empty loadcollectors |
Checks if there are any loads in the load collectors. |
Lists all loadcollectors that do not have loads. |
Deletes empty loadcollectors. |
Not supported. |
| Empty Vectorcollectors |
Checks if there are any empty vector collectors. |
Lists all empty vectors. |
Deletes empty vectors. |
Not supported. |
| Empty assemblies |
Checks if there are any empty assemblies. |
Lists all empty assemblies. |
Deletes empty assemblies. |
Not supported. |
| Shared laminates |
Checks if laminates are shared among parts. |
Lists the shared laminates. |
Not supported |
Not supported |
| BeamSection with invalid name (> 40 characters) |
Checks if there are any beam section name string has more than 40
characters |
Lists all the Beam Sections name string with > 40 characters |
Not supported |
Editing of Beam section names to < 40 characters |
| VectorCollector with invalid name (> 40 characters) |
Checks if there are any Vector name string has more than 40
characters |
Lists all the vectors name string with > 40 characters |
Not supported |
| Assembly with invalid name (> 40 characters)v |
Checks if there are any Assembly name string has more than 40
characters |
Lists all the Assembly name string with > 40 characters |
Not supported |
Editing of Assembly name string with < 40 characters |
| Material with invalid name (> 40 characters) |
Checks if there are any Material name string has more than 40
characters |
Lists all the Material name string with > 40 characters |
Not supported |
Editing of Material name string with < 40 characters |
| Property with invalid name (> 40 characters) |
Checks if there are any Property name string has more than 40
characters |
Lists all the Property name string with > 40 characters |
Not supported |
Editing of Property name string with < 40 characters |
| Component with invalid name (> 40 characters) |
Checks if there are any Component name string has more than 40
characters |
Lists all the Component name string with > 40 characters |
Not supported |
Editing of Component name string with < 40 characters |
| Set with invalid name (> 40 characters) |
Checks if there are any Set name string has more than 40
characters |
Lists all the Set name string with > 40 characters |
Not supported |
Editing of Set name string with < 40 characters |
| Group with invalid name (> 40 characters) |
Checks if there are any Group name string has more than 40
characters |
Lists all the Group name string with > 40 characters |
Not supported |
Editing of Group name string with < 40 characters |
| Contactsurf with invalid name (> 40 characters) |
Checks if there are any Contactsurf name string has more than 40
characters |
Lists all the Contactsurf name string with > 40 characters |
Not supported |
Editing of Contactsurf name string with < 40 characters
| LoadCollector with invalid name (> 40 characters) |
Checks if there are any Load collector name string has more than
40 characters |
Lists all the Load collector name string with > 40
characters |
Not supported |
Editing of Load collector name string with < 40
characters |
| SystemCollector with invalid name (> 40 characters) |
Checks if there are any System Collector name string has more
than 40 characters |
Lists all the System name string with > 40 characters |
Not supported |
Editing of System name string with < 40 characters |
| Element connectivity |
Checks for shell elements connected by one or less nodes and
solid elements connected by two or less nodes. |
Lists the failing elements. |
NA |
Not supported. |
