Configure Model Checker
Save configurations for future use, import existing configurations into your current HyperMesh session, or append configurations on top of existing configurations.
                Save configurations.
- In the white space of the Model Checker, right-click and select Save Config File from the context menu.
 - In the Save dialog, specify a file name and directory to save the external .xml configuration file and click Save.
                Add configurations.
                Import configurations.
                Use the
HM_MODELCHECKER_$profile_nameenvironment variable to set the default configuration file to be loaded for a profile. For example, set envHM_MODELCHECKER_LSDYNA=”D:/Customer/Checks.xml”will set the default configuration file for the LS-DYNA profile. Similarly,HM_MODELCHECKER_RADIOSSwill set the default configuration file for the Radioss profile, and so forth. After a configuration file is saved in a session, it becomes the new default file for that profile until the end of the HM session.
