Organize Checks
Organize new and existing checks inside of a user-defined Check Folder.
By default, checks are organized into the ERROR, WARNING, and INFO. You can create
                your own folder to organize checks in using the Check Folder entity.
        - ERROR
 - Checks with ERROR check-level, identifying modeling issues that need to be fixed to ensure the model to be run by the solver.
 - WARNING
 - Checks with WARNING check-level, identifying modeling recommendations or solver warnings to improve the quality of the model, but are not critical for the model to be run by the solver.
 - INFO
 - Generic information on the content of the model.
                In the Model Checker, right-click and select Create
                        Folder from the context menu.
                A new Check Folder is created, and opens in the Entity Editor.
 - In the Name field, enter a folder name.
                Organize checks inside the newly created Check Folder.
- Create new checks directly in this folder by right-clicking on the folder and selecting Create Check from the context menu.
 - Move existing checks by dragging-and-dropping selected checks into the folder.
