Whenever HyperBeam computes the section properties of the
current section, it displays them in the Results pane.
You cannot edit the text in this portion of the window for standard, shell and solid
sections, but you can select it and copy/paste it into another application. The only
way to change the parameters of a generic section is to edit the values in the
Results pane.
