2026
Explore the different types of 1D mesh you can create in HyperMesh.
View new features for Altair HyperWorks 2026.
Each element has an associated element configuration. An element configuration tells HyperMesh how to draw, store, and work with the element.
Solver cards supported for elements.
Use the Element Quality view to review element quality while simultaneously editing your model.
Models that require 0D and 1D elements can be created through controllers.
Edit density, size, or Chordal deviation along lines.
Apply linear, exponential, or bellcurve biasing to individual edges of a surface, and edit the elements size distribution.
The automeshing process enables you to bias the placement of nodes so that their intervals are not uniform in size.
Explore the different types of 2D mesh you can create in HyperMesh.
Explore the different types of 3D mesh you can create in HyperMesh.
Create, organize, and manage parts and subsystems.
The Developer ribbon contains tools for automation and customization.
Plot data can be post-processed using both HyperMesh and HyperGraph.
