Edit Density, Size, or Chordal Deviation
Edit density, size, or Chordal deviation along lines.
- From the microdialog, click and select the desired method.
- Left-click to select the edge(s) to modify.
Edit element density or size in the following ways:
- Increase individual edge values by holding Ctrl while left-clicking on an edge; decrease individual edge values by holding Ctrl while right-clicking on an edge.
- Scroll edge values by holding Ctrl while scrolling the mouse wheel up and down. Hovering directly over an edge will only modify that edge; hovering over empty space will modify all selected edges.
- Specify an edge value in the microdialog and press Enter. If multiple edges are selected, a common value will be applied. If multiple edges with different edge values are selected, use the arrows in the microdialog to modify individual edge values simultaneously, without applying a common value.
Tip: Clear your selection by left-clicking in empty space.
