Safety Tools
New Features
Bus Rollover Workflow
The Bus Rollover workflow allows you to automatically setup the impact load case as per the ECE-R66 safety regulation. The tool is available in the Radioss, LS-DYNA and PAM-CRASH profiles.
Enhancements
Seatbelt Tool
Deletion of seatbelt: A new dialog is exposed to decide if the solver entities have to be deleted as well or not.
Figure 3.
New features to create multiple cross-sections on a seatbelt segment.
Figure 4.
The node selector on seatbelt control point is now activated, allowing you to update the location of control points without re-defining the complete seatbelt segment path.
Figure 5.
Review of seatbelt control points now uses the color of the related seatbelt segment.
Beam elements defined on seatbelt 2D mesh are automatically recognized when using the seatbelt extraction tool.
Sets of elements defining the mesh per seatbelt segment are automatically created and referred to in seatbelt metadata. This allows the compatibility of HyperMesh seatbelt tool and seatbelt meshes coming from different pre-processors.
Resolved Issues
  • Mechanism Tool: Motion of geometry is again possible when bodies contain components with geometry.
