Altair HyperGraph 2024.1 Release Notes
General
New Features
Math Tool
The Math tool functionality has been migrated from a panel to the Math Macro dialog. From the ribbon, select the Math tool to display the dialog.
Values Tool
The Values tool functionality has been migrated from a panel to the Values dialog. From the ribbon, select the Values tool to display the dialog.
Complex Plot Options for Curve Creation
Support for complex plots has been added to the Create Curves by File dialog > Plot Options tab.
Figure 3.
Edit Templex Function Categories in the Define Curve Dialog
You can now edit categories for Templex functions in the Define Curves dialog.
Figure 4.
Enhancements
Python API
The Python API has been expanded to include additional HyperGraph chart types.
The following classes have been implemented and/or enhanced:
  • CreateCurvesBySubcase() creates multiple XY plots looping over subcases from a single file.
  • MultipleSubcases() creates a subcase set that can be used to plot from multiple subcases simultaneously.
  • CreateCurvesOptions() modifies the curve options while plotting XY curves, similar to the Create Curves by File dialog.
    Figure 5.
  • CurvePolar() and CurveBar() provide API support for the chart types 'bar' and 'polar'.
  • CreateCurvesByFile() has been enhanced to plot multiple polar and complex plots simultaneously.
    Figure 6.
  • Window() class updates for bar and polar plots have been added.
    Figure 7.
  • DataFile() extracts component channel lists in a complex syntax which then can be used to plot complex and polar plots, similar to the Create Curves by File dialog.
  • MCFRACTION results for a modal transient response has been implemented for OptiStruct files.
  • PSDF and CRMS values for nodal results support for OptiStruct files.
  • Cross-PSD results and cross-correlation function support for OptiStruct files.
  • Multiple improvements to the Notes tool.
  • The 3D Chart Build Plots dialog has been converted to Qt.
  • SEAM reader enhancements for reading files with unwanted data.
Resolved Issues
  • UTF character support in folder names.
  • New Templex functions for debugging.
  • Additional bug fixes.
Solver Interfaces
OptiStruct Interface
Enhancements
Extensions
Resolved Issues
  • Removing and re-adding extensions now works properly. Re-added extensions now appear in the ribbons, toolbars, and menus as expected.
