Altair PhysicsAI 2024.1 Release Notes
New Features
Models Can Now be Trained to Predict Multiple Responses
You can now train a single physicsAI model for predicting multiple results, such as stress and displacement. You can select multiple check boxes in the Outputs section of the model training window. This feature can save considerable time and effort.
Improved Visualization for Custom Outputs (KPIs)
The visualization for custom outputs has now been enhanced in the form of scatter plots and continuous curves. This is especially useful for time dependent responses. Additionally, results for all test data-points are displayed simultaneously for easy comparison.
Figure 3.
Support for Modal Analysis
PhysicsAI now supports modal analysis predictions, including out of phase results.
Figure 4.
Transfer Learning is Now Visible by Default
Transfer learning is now enabled by default in the training window. Transfer learning enables the reuse of knowledge from previous models resulting in better accuracy and faster convergence of subsequent model trainings. The width, depth, and input features in the new model must be equivalent to the pre-trained model for it to be reusable. The output field dimensionality and number of timesteps can be different from the pre-trained data.
Figure 5.
Enhancements
Visualization Settings Saved in HyperView
The predicted and true results now move synchronously in HyperView. Additionally, sections and hidden components are also synced. This saves effort, as it would otherwise require manual orientation.
Predictions on Altair One
PhysicsAI on Altair One now supports predictions in addition to training. An interactive visualization of results is available similar to the experience in HyperMesh.
Figure 6.
Training Using Physical Test Data
Previously, physicsAI required contoured results data when training on custom outputs. Mesh-only files (.fem, .rad, and so on) without any contour data can now be used for training on KPIs.
Known Issues
In dark mode, the test animations comparison will not display until the Model Testing dialog is closed.
