Model Build
New Features
- Subscribe is now available in the context menu if a Teamcenter repository is registered.
- PostGreSQL 16.2.1 is now supported for Part Library.
- Constraints are now owned by Parts. This applies across Abaqus, LS-DYNA, and Radioss.
- Constraints can be organized between parts in order to create collections of constraints.
- When opening models containing constraints, parts will be automatically created and the constraints will be organized into those parts.
- Constraints are colored by the part they are organized into. A constraints own color has been removed.
- Constraints will be saved into part representations
- Abaqus:
- Node set based constraints will be fully saved into part representations.
- Element set based constraints will only save elements associated to the part selected for saving.
- Abaqus:
- When exporting a solver deck, only include file statements for active subsystems will be written. This means subsystem configurations can be exported without needing to use the Write include file statements only for exported includes option.
Enhancements
- The Move Contents to Current and Move to Current context menu options have been replaced with Organize.
- Deleting a part will always delete it's content, there is no longer an option to keep content.
Resolved Issues
- The issues with copy and paste of a part and subsystem have been resolved.
- Constraints will now be saved into subsystem representations.
- The issue with parts being incorrectly positioned on Instance Link operation has been resolved.
Known Issues
- Copy and paste of a part copies the part’s entire assembly hierarchy.
