Edit the Mesh Type/Mapping Method and Define Free Surfaces
Use the Map: Face Edit tool to edit the mesh type and mapping method of individual target/source surfaces. You can also define free or unmapped surfaces by selecting points.
From the 3D ribbon, click the tool.
Figure 1. - Optional:
On the guide bar, click
to define surface mesh options.
- Select the surface(s) to edit.
- In the microdialog, select a mesh type and mapping method to apply to the selected edge(s).
Define free or unmapped surfaces.
- On the guide bar, change the selector to Points using the drop-down menu.
- Left-click on the four corner points that make up a surface identified as Free (unmapped).
Mesh to update the map mesh.
If the Auto update option is tuned off, first click Update to modify the 2D mesh.
Tip: Clear your selection by left-clicking in empty space.
