Align 3D Image Planes
- From the 3D Image Plane tab, click the Alignment sub-tab.
Under Mode, select the input scheme to be used for scaling and
orientation.
- 2 Point - Two points are used to scale the image
to the model, while the orientation of the plane is specified using the
Plane option.Note: This method is useful for orienting media that are primarily captured in near orthogonal views (Top, Left, Front, Bottom, Right, and Rear).
- 3 Point - Three points are used for orientation
of the image plane in model space. Two of these points are used to scale the
image to the model.Note: This is useful when standard views are not being used to view images (for example, the images are being viewed on sharp angles).
Plane option.
If the 2 Point method was selected, you must define the plane and pick the
reference points on the image and on the model.
If the 3 Point method was selected, you must pick the reference points on the
Click Align to scale the image plane to the 3D options
selected.
Attention: The alignment and scaling are dependent on the accuracy and closeness of the points selected on both the video/image and the model. It is recommended that you select two points (or three in the case of a 3 point alignment) which lie on the same depth level. For example, when looking at a car from left side view, points that are on the same side and at similar view depths should be selected (like the left side tires). Incremental adjustments to orientation can be performed with the help of graphical manipulators.The plane is embedded in the modeling window. In addition, a new view is created in the Views entity folder in the Results Browser.Tip: The Views section of the Results Browser and the Entity Editor can also be used modify various image plane view settings.
