Offset Curves Along the Vertical Axis
- Select the curves from the list or pick them from the window.
- Activate the Y Offset check box.
- Enter the distance to shift the curves in the Y Offset text box.
Click Apply to accept the new scaling values.
The data is shifted up for positive values and down for negative values.
