Move Curves Along the Vertical Axis
- Select the curves from the list or pick them from the window.
 - Activate the Y check box.
 - Enter a new Y coordinate for the origin of the curve in the Y Move to text box.
                Click Apply to move the start point for the selected
                    curve(s).
                The selected curves are moved up for positive values and down for negative values.
