Offset Curves Along the Horizontal Axis
- Select the curves from the list or pick them from the window.
- Activate the X Offset check box.
- Enter the distance to shift the curves in the X Offset text box.
Click Apply to accept the new scaling values.
The data is shifted to the right for positive values and to the left for negative values.
