Radioss to OptiStruct Conversion Mapping
Contacts
Radioss | OptiStruct |
TYPE2 | TIE |
/TYPE24 | CONTACT, AUTO, PCONT, PSURF |
/TYPE25 | CONTACT, AUTO, PCONT, PSURF |
Elements
/ADMAS | CONM2 |
BEAM | CBEAM |
BRIC20 | CHEXA |
BRICK | CHEXA, CPENTA, CTETRA |
PENTA6 | CPENTA |
SH3N | CTRIA3 |
SHELL | CQUAD4 |
SPRING + PROP/SPRING (TYPE 4) | CBUSH1D |
SPRING | CBUSH |
TETRA4 | CTETRA |
TRUSS | CROD |
Engine Keywords
/RUN | TTERM |
Loads
/CLOAD, /FUNCT | FORCE, DLOAD, TLOAD, TABLED1 |
/GRAV | ACCEL2 |
Materials
MAT/COMPSH (LAW 25) | MAT9ORT** |
MAT/ELAST (LAW 1) | MAT1 |
MAT/HONEYCOMB (LAW 28) | MAT9ORT + MATX28* |
MAT/PLAS_JOHNS (LAW 2) | MAT1 + MATX02* |
/MAT/PLAS_TAB | MAT1, MATS1, TABLEMD |
MAT/PLAS_TAB (LAW 36) | MAT1 + MATX36* |
MAT/VOID (LAW 0) | MAT1 + MATX0* |
*Only when you click Yes in the RadiossBlock to OptiStruct conversion tool dialog.
**The values of NU23 and NU31 are set to default values on conversion.
Properties
PROP/BEAM (TYPE 3) | PBEAM + PBEAMX* |
PROP/SH_SANDW (TYPE11) | PCOMP** |
PROP/SHELL (TYPE 1) | PSHELL + PSHELLX* |
PROP/SOLID (TYPE 14) | PSOLID + PSOLIDX* |
/PROP/SPR_BEAM | PBUSH |
PROP/SPR_BEAM (TYPE 13) | PBUSH + PBUSHT |
PROP/SPR_GENE (TYPE 8) | PBUSH + PBUSHT |
PROP/SPR_PUL (TYPE 12) | PBUSH |
PROP/SPRING (TYPE 4) | PBUSH1D |
PROP/TRUSS (TYPE 2) | PROD |
**Only material, ply thickness, and ply angle is converted.
