Voltage/current source: about
Voltage/ current sources
The source components: source of voltage and source of current can be created:
  • within the electric circuit editor context (graphically visualized component)
  • with the circuit import (graphically visualized component depending on the format)
  • directly in Flux (non visualized graphically component )
Graphic representation
In the circuit editor, the components are represented by the following graphic symbols:
Current source Voltage source
Orientation
The orientation of the sources defines the direction of the current in the electric circuit.
Electrical model
There are the characteristics of definition for each source component current source and voltage source components proposed for each physical application.
