Compatibility of components according to the application
Compatibility component/application
The table below presents the compatibilities between components and the applications implemented with the Flux software:
Component Magneto static Steady Stat AC Magnetic Magnetic transient Magneto thermal
Flux2D Flux3D Flux2D Flux3D Flux2D Flux3D Flux2D Flux3D
Resistor X X X X X X
Inductance X X X X X X
Capacitor X X X X X X
Source of voltage Sinusoidal voltage source X X X X
Voltage source to be defined X X
Source of current Sinusoidal current source X X X X
Current source to be defined X X
Coil conductor current X X X X X X X X
Coil conductor circuit X X X X X X
Solid conductor 2 terminals X X X X X X
Solid conductor N terminals X X X
Switch ron roff X X
Diode Diode_uc_i_ron_roff X X
Diode_uc_i_exp_vf0_rb X X
Diode_uc_i_exponential X X
Brush-segment X X
Squirrel-cage X X X X X X
Ground X X X X X X
