Deletion of an electric circuit
Introduction
The deletion of the electric circuit permits to destroy the assembly of electric components, as well as the assembly of equipotential points.
Delete the electric circuit
To delete the electric circuit, starting from the standard context or from the electric circuit editor context:
Step Action
1
To activate the command choose one of the following actions:
  • in the standard context:
Point on Circuit and click Delete circuit in the Physics menu
or
  • in the circuit editor context
  • click on Delete circuit in the Circuit menu
→ A dialogue box Delete circuit is opened.
2
Fill the fields:
  • choose the deletion or not of the coil conductors *
3
Validate the information:
  • click on OK
→ The electric circuit has been deleted.
Note: * This is only valid for the coil conductors belonging to the circuit. The coil conductor components with imposed current will not be deleted.
