Circuit coupling: software aspects
Context
The electric circuit editor context
Operation in the electric circuit editor context
Manipulation of electric circuit components in the circuit editor context
Data
The available data:
The various components of the electric scheme
Action (1)
Procedure for circuit management:
Description of an electric circuit in the circuit editor context
Description of an electric circuit via format XmlCir import
Description of an electric circuit via importing of other formats (CCS, TXT, CIF)
Verification of the electric circuit
Actions (2)
Procedure for field/circuit coupling management:
Management of coupling between the finite elements domain and the electric circuit (2D application)
Management of coupling between the finite elements domain and the electric circuit (3D application)
Sequencing
The (simplified) sequences of the commands:
2D magnetic applications (with electric circuit) : sequencing of commands
3D magnetic applications (with electric circuit) : sequencing of commands
Reading advice
For the theoretic aspects (principles), refer to chapter Circuit coupling: principles
