Voltage/current source: definition (structure)
Definition
A voltage source or current source component is defined by:
  • a name (and a comment)
  • a model
  • specific characteristics depending on the model
  • two terminals
Name
The name permitting the identification of the component is given by the user when it is created.
A comment (optional) can be added to the name.
The name and the comment are displayed by default in the graphic zone close to the symbol.
Source components: description
Characteristic quantities, necessary for the description of the source components: voltage source and current source, are presented in the table below.
Source Function
time dependent complex
voltage source U(t) = formula U(t) = U0ej(ωt + φ)
Rms value
Phase
current source I(t) = formula I(t) = I0ej(ωt + φ)
Rms value
Phase
