Automatic saving of the circuit
Introduction
An automatic saving of the circuit is carried out in order to retrieve the circuit* if Flux is closed without saving.
Limitation linked to the circuit
All the manipulations carried out in the electric circuit editor context are not recordable in the Flux3D_log.py file or in the Flux2D_log.py.
Indeed, the file would be overcharged because of the numerous available manipulations. Moreover, the authorized number of characters is limited while executing a Pyflux file.
Automatic saving of the electric circuit
By contrast, at each exit of the electric circuit editor context, an export of the circuit towards a NameofProject_logX.xcir file is created under the project root and the following commands are added in the Flux3D_log.py file or in the Flux2D_log.py file:
- Suppress the circuit
- Import the circuit NameofProject_logX.xcir* with the options:
- all the values of the components
- the couplings electric circuit - finite elements domain
