Propagate points / Propagate lines
Before starting
It is necessary to have a transformation (created beforehand) and points / lines to be able to propagate points / lines.
Propagate points / lignes
To propagate points / lines:
Step Action
1
Select the points / lines to propagate:
  • in the Select menu click on Select points / Select lines
    (or on the icon / )
  • in the graphic scene click on the point / line of interest
    (Keep pressed the Ctrl key for a multiple selection.)
2
Activate the command *:
  • open the contextual menu with the right mouse button
  • click on Propagate points / Propagate lines in the contextual menu
→ A new dialogue box is opened.
3
Fill out the fields:
  • choose a transformation
  • enter the number of the successive executions of the transformation
4
Validate the information:
  • click on OK button
→ The points / lines are created.
→ A new dialog box for the extrusion of entities of the same type is automatically opened.
5
Quit the sequence:
  • click on Cancel button
Note: * You can also activate the propagation command by clicking on Propagate points / Propagate lines in the menu Geometry > Propagate (or on the icon / ).
