Adding a Waveguide Source
Add a waveguide source to the first port using the fundamental mode.
Note: Default values are used in this example. The fundamental mode for this source will
be excited (TE10).
Add multiple modes as a single source by selecting Specify modes manually.
On the Source/Load tab, in the
Sources on Ports group, click the
Waveguide Source icon.
In the drop-down list, select
WaveguidePort1.
Figure 1. The Create Waveguide Source dialog.
- Click Create to create the source and to close the dialog.
