Create the waveguide sections using two cuboids.
Create the first waveguide section.
On the Construct tab, in the Create Solid group, click the
Cuboid
icon.
Create the cuboid using the Base centre, width, depth,
height definition method.
Use the following dimensions:
- Base centre (C): (0, 0, 0)
- Width (W): wg_w
- Depth (D): 2*wg_w
- Height (H): wg_h
- Label:
Cuboid1
Figure 1. The Create Cuboid dialog.
Click OK to create the waveguide section and to
close the dialog.
Create the second waveguide section.
Cuboid
icon.
Create the cuboid using the Base corner, width, depth,
- Base corner (C):
(wg_w/2, -wg_w/2, 0)
- Width (W): wg_w
- Depth (D): wg_w
- Height (H): wg_h
- Label:
Cuboid2
Figure 2. The Create Cuboid dialog.
close the dialog.
Figure 3. The two waveguide sections and power dividing pin.
