Creating the Power Dividing Pin
Create the power dividing pin using a cylinder.
Create a cylinder located at the origin along the Z axis.
Note: Default values are used on geometry creation dialogs to allow a preview in the 3D view. You may change the values as required.
- Click Create to create the cylinder and to close the dialog.
Figure 1. The Create Cylinder dialog.
Zoom to extents of the 3D view using one of the following
workflows:
- On the View tab, in the
Zoom group, click the
Zoom to
extents icon. - Press F5 to use the keyboard shortcut.
