Setting Local Mesh Sizes for Waveguide Port Faces
Refine the mesh locally at the waveguide port faces. The faces for the waveguide ports require a finer mesh to represent the highest mode that should be taken into account. The higher order modes are typically evanescent modes.
- In the 3D view, select the three waveguide port faces.
- From the right-click context menu, select Properties.
On the Multiple Entities dialog
(Meshing tab), specify the following:
Click OK to apply the properties and to close the
dialog.
Figure 2. Note the localised mesh refinement at the waveguide port faces.
Note: The
icon in the details tree indicate that
a local mesh setting is applied.
