Simulation and Analysis of the Cone Penetrometer test
This section provides instructions for running an EDEM simulation of the Cone Penetrometer test and automatically computing the pressure vs penetration depth curve and other relevant results.
Introduction
EDEM simulation decks are provided for the standard ASAE S313.3. test method, but the analysis methodology is applicable to any cone penetration simulation where the motion of the cone is along the global Z axis.
Prerequisites
All the requisite files are located at: <Altair installation folder>\EDEM <version>\examples\Calibration Kits\Cone penetrometer.
Using the kit
| Parameter | Description |
| Penetration start time (s) | Specifies the simulation time at which the cone pressure starts to be recorded (in seconds). The nearest saved Time Step is used for the analysis. Alternatively, you can specify ‘auto’ as a string, in which case the time at which a non-zero cone pressure first occurs is used. |
| Penetration depth (m) | Specifies the total cone travel distance after the penetration start time over which the cone pressure is recorded (in meters). Alternatively, you can specify ‘auto’ as a string, in which case the pressure is recorded over all the saved Time Steps after the penetration start time. |
| Averaging resolution (m) | Specifies whether, in addition to the raw cone pressure vs penetration depth curve, the results will be reported according to the ASAE S313.3. standard, and the averaging resolution (in meters) is used for this purpose. |
| Create results report (yes/no)? | Specifies whether an individual results report is written out
for every simulation deck and stored in its folder in
.csv format. |
| Summary report? (yes/no) | Specifies whether a summary report with the key results for
all simulation decks is produced. The results are written out in
the Summary.csv file in the Python script
folder. |
| Plot figures? (yes/no) | Specifies whether a plot of the raw cone pressure vs
penetration depth is created per simulation deck and stored in
its folder in .png format. |
A settings text file is required for each folder containing EDEM simulation decks, and the settings are used to post-process all simulation decks in that folder.
The provided Python script can be executed from , or from the command line. To run the script from the command line, you must ensure that EDEMpy is installed in the relevant Python distribution. For more information about installing EDEMpy, see Install EDEMpy.
