Simulation and Analysis of the Rotational Shear Cell test
This section provides instructions for running a simulation of a rotational shear cell and extracting the relevant data automatically using the provided files.
The response of the sample is measured in the critically consolidated state and in the quasi-static flow regime. These conditions correspond to the ones encountered during storage and discharge of silos and bins but may not be representative of highly dynamic and/or low stress systems such as mixing or conveying for example.
The simulation and analysis methodologies outlined in this section are applicable to all commercially available rotational shear cells, of which EDEM decks are provided for the Schulze RST XS and Brookfield PFT instruments.
Prerequisites
The simulation and analysis procedure described in this section requires EDEM version 2022 or later. All the requisite files are located at: <Altair installation folder>\EDEM <version>\examples\Calibration Kits.
Copy the Calibration kit and examples to a processing folder before they are configured and run. The analysis described in this section uses EDEMpy. For more information about EDEMpy, see the EDEM Help documents.
Running the Simulations
EDEM decks are provided for the Brookfield PFT tester (152mm diameter cell) although the simulation procedure can be used to run any rotational shear cell.
Run the deck that is provided directly in EDEM until the end.
The stages of the shear test described in Figure 2 are modeled using EDEM kinematics controllers as shown in Figures 4 and 5 for the vane lid and through components respectively. The normal stress application in the physical test is achieved via a PID controlled servo, which applies a vertical correction to the vane lid position over time to maintain the normal stress. This procedure is approximated in EDEM by reducing the mass of the vane lid to limit inertial effects, capping the lid velocity and applying linear damping. Achieving an accurate and controlled normal stress application with this approach may require an adjustment of the maximum vane lid velocity as show in Figure 4. Using a maximum velocity of five average particle diameters per second typically yields good results.
Rotational shear cell tests produce measurements in the quasi-static flow regime where the macro-mechanical behavior of granular materials is strain rate independent. Therefore, the shear rate in the provided decks is accelerated in the interest of computational efficiency. If the particle properties or the applied normal stresses in the model change significantly, the strain rate may need to be adjusted to ensure the quasi-static flow regime is maintained. This can be achieved by changing the through rotational velocity as shown in Figure 5.
The simulation utilizes quarter symmetry in the interest of computational efficiency. This should not have impact the results of interest. The complete cell with no quarter symmetry can be modeled by deleting the periodic boundaries and resizing the domain.
Post-processing results automatically with EDEMpy
Shear_cell_analyst_v3.py script:- Arrange the files as shown in Figure 7.
- Open a blank or existing EDEM simulation file, and go to .
- Go to and then select the
Shear_cell_analyst _v3.pyscript.Reports and graphs will be generated in the master folder. Only complete simulations with the corresponding settings files will be post-processed. Otherwise the script will produce error messages as shown in Figure 7, and then move to the next simulation in the folder tree.Note: All simulation files must have unique folder names and simulation names. If the simulation names are identical, the results report will be overwritten.Figure 8. Possible error messages
Script Version changes
Version 3 of the Dynamic Angle of Repose analysis script is designed to work with
EDEM version 2022.0 (and later) and EDEMpy. This EDEMpy version
includes a change where creatordata is indexable, and all
references to creatordata have been replaced with
creatordata[0].
