The Type C Rolling Friction contact model, proposed by Ai et al. (2011), is
an extension of the Standard Rolling Friction model.
This model includes a non-viscous term in the damping torque equation.
Where Mr is the total damping torque vector, Mrk is
the non-viscous damping torque vector and Mrd is the viscous
damping torque vector. The non-viscous damping torque vector is a function of the
relative particle rotation angle and the rolling stiffness as defined in Equations 2
and 3.
Where k
r is the rolling stiffness, θ
r is the relative
rotation angle, R
r is the equivalent rolling radius, k
n is
the normal contact stiffness and μ
r is the Coefficient of Rolling
Friction.
Note: The non-viscous torque magnitude is limited
according to Equation 4, where F
n is the normal contact force.
The
viscous damping torque vector is defined in Equation 5 and is a function of
the relative rotational velocity vector at the contact point and the rolling
viscous damping ratio.
Where η is the rolling viscous damping
ratio, Ir is the equivalent moment of inertia for the rotational
vibration mode about the contact point, and ω is the relative rotational
velocity vector at the contact point.
The viscous damping torque is
only applied if the non-viscous torque magnitude is below the limit as
defined in Equation 4. In cases where significant non-viscous rolling
resistance is expected at particle contacts, such as when contact forces are
high or the modeled material consists of predominantly angular particles,
the use of Type C Rolling Friction may result in a more physically accurate
behavior and greater stability of the EDEM
model.
