Retrieve Material Forces Acting on Geometries
You can retrieve the summed material force and torque acting on the specified
Geometry using the getGeometryForces
method.
- Specify the point of action for the Geometry to calculate the torque.
- With this data, calculate the dynamic response of the equipment represented by the Geometry.
