Design of Experiment-style Studies
Design-Of-Experiment (DOE) style programs or parametric CAD packages allows equipment designs to evolve through co-simulation. This capability in the EDEM Coupling Interface also allows you to automatically create many simulations containing variations on Geometry or Geometry dynamics for running in batch mode.
Importing a Geometry
The loadGeometry
method will create a new Geometry section in the
EDEM simulation and name it using the CAD file name
which is read in. The import process will use the same default parameters as shown
in the EDEM Creator Geometry Import dialog box. Any
changes to the defaults can be specified via the
setGeometryImportParameters
method, which should be invoked
prior to calling the loadGeometry
method.
Assigning a Material to a Geometry
Prior to loading a Geometry, you must specify the material to assign to the Geometry
section that is about to be loaded. The relevant ID is obtained via a call to the
getMaterialId
method.
Deleting a Geometry
Use the name of the target Geometry to delete it from the simulation via a call to
the removeGeometry
method.
Assigning Kinematics to a Geometry
addLinearTranslationKinematic
addLinearRotationKinematic
addSinusoidalTranslationKinematic
addSinusoidalRotationKinematic
addConveyorTranslatonKinematic
addConveyorRotationKinematic
