By default, EDEM will launch with the Coupling Server
stopped and requires you to start the server before a coupled simulation can proceed.
To start and stop the Coupling Server:
For running in batch mode or for further automating the process, you can launch
EDEM with the Coupling Server already running by
adding the ‘--cs’ switch to the command line.
The coupling will connect on a random port. If you want to specify the
port used for the coupling, enter a value in the coupling box.
Note: To use user-specified ports, the coupling must
be updated, and you must specify a port on the client side as
well.
C++ Coupling
The flag –cs-port followed by a specific port will
start the coupling server using this flag.
The ports will only allow connection on ports in the range of 32768 to
65535.
If both --cs and --cs-port are
specified, --cs-port will take precedence.
Python Coupling
When connecting to the coupling using the command
connectCoupling(), you can specify a port
number.
If you do not specify a port number, a number between 0 and 32969 will
be used.
