Test End-to-End Flow
The logic Function runs on a schedule as well as on telemetry input.
- To trigger the logic Function using the telemetry, click and open the Details pane for the Simple Thermal thing.
Fill in a value for the
inputHeatFlowand click Save Values. Repeat this if you want to see multiple inputs.You should see the results of the simulation stored in theoutputTemperatureproperty. -
Open the Properties History pane to view the list of the results.
