Create an Access Control App
- The second Function you will create later will need client credentials to make API calls. Click .
Create a new App with Scopes set to function and
thing, and the Type set to Client
Credentials.
- Go to the Authorization pane and select role::root from the Roles drop-down menu and click Save.
Copy the Client ID and Client
Secret and keep them locally for later use in a Variable. For
more details on the Client Secret read the Access Control section of the documentation.
After creating the App you might have to re-generate the Client Secret so you
can copy it; do not re-generate the secret after that (any client using the old
secret will stop working).
