Create a Variable to Store Credentials
To make the Client ID and Secret available for use in the logic Function, you need to store them in a Variable.
  1. Expand the Space Settings section in the menu and click on Variable Storage.
  2. Click +New Variable to create a new variable.
  3. Use the name app-for-functions with type App Credentials.
  4. Paste the previously copied Client ID and Secret into the appropriate fields, enable Allow Function Access and click Save.
