Marketplace
Marketplace provides you with predefined sets of applications for the Edge.
You can conveniently browse, discover, and import the Edge application to your own project space to build and manage the Edge solution at scale in a few clicks.
When a new version is added to an application listed in the Marketplace, it automatically becomes available as an update to the imported Edge Application.
Marketplace contains applications that run on the Edge, starting from pre-defined sets of applications built by our engineers, third-party applications to any other container-based applications you want to install at the Edge can be defined in the Marketplace.
