Help files
FluxMotor command help files
This section corresponds to the command “Open FluxMotor command help files” available in the expanding menu at the top part of Script Factory.
Table 1. How to access the FluxMotor python script command help?
1 Select “Open FluxMotor command help files” option.
2
List of available DSL (Domain Specific Language) commands dedicated to the main applications of FluxMotor.
One must select the one in which the targeted commands are stored.
3 The command list is displayed. One must click on the command name to see the corresponding description.
Log and error
Table 2. LOG and ERROR tabs
1 LOG tab gives the information for each command executed in the software and to check whether the command has been executed correctly or not.
2 ERROR tabs give the error message (as a popup does in GUI environments).
