Site and Transmitter Data
Sites and antennas in ProMan have many properties, such as position, name, antenna pattern, azimuth, downtilt, frequency, power, and more. When you have defined a number of sites, antennas and their properties in one project and need to use a similar configuration in another project, it can be convenient to export the relevant information to a suitable file and import it into another project. This saves time when setting up new projects that are similar to existing ones, and reduces the chance of errors.
The following options are available to import or export site and transmitter data:
- Use a .csv file to import/export only selected or all properties of the sites and antennas.
- Use a .net file to import all properties of the sites and antennas.
- Use a .trx file to import/export all properties of the sites and antennas.
