Break
This tool is used to break a set of bodies or faces using a plane, cylinder, box, polygon and cone.
Plane
This is used to break a body or set of faces on FEM/CAD model using a plane. The plane can be defined using Define/Modify Plane button.
CAD (Parasolid)
Select Break bodies with Combine as connected body toggle OFF to split the body into two along the defined plane.
Select Break bodies with Combine as connected body toggle ON to create connected body along the defined plane.
Select Break faces to break faces along the defined plane.
Select Create sheet body from cut section to create a sheet profile from the cut section.
This is supported only for CAD (Parasolid) imported with Save geometry in database option enabled.
- In case of Parasolid input, finite plane break is also supported.
Break bodies:
Break bodies with combine as connected body:
Mesh
Select Create internal face to create internal faces while breaking.
Select Break bodies to split the body into two.
- In case of mesh input, it creates an edge group with name Break_Face_Edges when faces are input with Create Face toggle off.
Cylinder
This is used to break a body or set of faces on FEM/CAD model using a cylinder. The cylinder can be defined using Define/Modify Cylinder button.
In case of CAD, supported only for Parasolid models.
Mesh
CAD (Parasolid)
Box
This is used to break a body or set of faces using a box. The box can be defined using Define/Modify Box button.
Select Break body to break the body.
Select Break face to break only the faces.
- In case of CAD, supported only for Parasolid models imported using Save geometry in database option enabled.
- Face break by Box is not supported for CAD (Parasolid) bodies.
Mesh
CAD (Parasolid)
Polygon
This is used to break a body or set of faces using a polygon (set of edges) in linear and circular direction.
Use Define/Modify Direction button to define the direction for linear option.
Use Define Axis button to define the axis for circular option.
Select Break bodies to split the body into many.
Cone
Mesh
This tool is used to break faces of body or set of faces using a cone. The cone can be defined using Define Cone button.
- CAD (Parasolid)
This tool is used to break Parasolid body imported with Save geometry in database option, using a cone. The cone can be defined using Define Cone button.
