Solution Methods
Analysis > Options > Solution Methods
The Solution Methods dialog provides the options to specify the solution methods for the model.
The following solution methods are supported for faces (triangles):
  • Methods of Moments (MoM / MLFMM)
  • Physical Optics (PO)
  • Large Element Physical Optics (LE-PO)
  • Faceted Uniform Theory of Diffraction (fUTD)
  • Ray Launching Geometrical Optics (RL-GO)
The following solution methods are supported for volume regions (tetrahedra):
  • Finite Element Method (FEM)
  • Volume Equivalence Principal (MoM VEP)
