Import CAD
File > Import > CAD
Altium Designer
This option is used to import Altium ECAD files with extension *.pcb and *.pcbdoc.
Refer the following link to know more about the various ECAD import options
IPC-2581
This option is used to import IPC-2581 ECAD files with extension *.xml and *.cvg.
Siemens PADS
This option is used to import MentorGraphics PADS ECAD files with extension *.asc.
Siemens Expedition Enterprise
This option is used to import MentorGraphics Expedition ECAD files with extension *.hkp.
Zuken CR-8000/CR-5000
This option is used to import Zuken CR-8000/CR-5000 files with extension *.pcf,*.dsgf,*.pnf and *.mdfg.
Cadence Allegro
This option is used to import Cadence Allegro Expansion ECAD files with extension *.brd,*mcm, and *Geom.txt.
GDSII
This option is used to import GDSII files with extension *.gds.
Refer the following link to know more about the various GDSII_Import_Options
Translate to Parasolid through Spatial
Various CAD format files are converted into Parasolid file using the Spatial Translator and then the converted Parasolid file is imported into SimLab.
Note:
  • For Translation using Spatial In Linux, motif library (system component) needs to be installed. If using CentOS, then motif library can be installed using the following command: sudo yum install motif For other Linux distribution, use corresponding standard way to install motif shared library.
Translate to Parasolid through CT
Various CAD format files are converted into Parasolid file using the CT translator and then the converted Parasolid file is imported into SimLab.
Translate to STEP
Various CAD format files are converted into STEP file using the CT translator and then the converted STEP file is imported into SimLab.
