Antenna Array
The Antenna Array dialog provides options to define an antenna array using RX antennas.
Pattern
Select the pattern of the antenna array. The following patterns are supported:
- Single Element
- Linear / Rectangular
- Circular / Cylindrical
- Custom
Rotation
Define the rotation of the full antenna array. The following methods are supported:
- Three axes: The antenna array is rotated around the X and Y and Z axes using the specified angles in degrees.
- Down tilt & Azimuth: The antenna array is rotated using the specified angles in degrees. Down tilt is the downwards angle from the vertical axis. The azimuth angle = 0° points in the X direction and azimuth angle = 90° points in the Y direction.
Antennas in Array
In the table, specify each RX antenna in the antenna array. For custom arrays, each RX antenna can be given an X, Y or Z offset.
